yes, but then it's not main seal. sorry.There's a seal where the torque converter connects to the transmission. Agree with Bondo, transmission stop leak rarely works.
It only seems like alot the first time you do it. Remember to use jack stands. They will save your life.I cleaned up everything I could reach and ran it a few days. The leak is from the oil seal where the passenger side half axle goes into the tranny. A lot to take apart to replace a five dollar seal.![]()
:thumbup: I've read horror stories on car forums, and always feel the need to mention jack stands everytime someone works on a car. Good to know you have it covered.I had the van on a pair of 8000 pound rated ramps, wheels chocked on. Both sides, parking brake on. I also have a pair of three ton and six Tom jack stands for use if needed. I never get under a car without proper support.
I had a car fall off a jack once. I was standing beside it; no injuries, but not something you forget. I had to replace a starter in a downtown parking garage and it took two trips on the bus to get the jack stands and blocks to the car.:thumbup: I've read horror stories on car forums, and always feel the need to mention jack stands everytime someone works on a car. Good to know you have it covered.
When I was younger, I jacked up my truck to look at the rear brakes. My intentions were to pull the drum off and decide if I need new shoes, then put the drum and wheel back on. I figured that this wouldn't take long, so why bother getting jack stands, right?I had a car fall off a jack once. I was standing beside it; no injuries, but not something you forget. I had to replace a starter in a downtown parking garage and it took two trips on the bus to get the jack stands and blocks to the car.![]()
Ayuh,... But it's a 'ell of alot Less work than pullin' the tranny to change the T/C Seal.....I cleaned up everything I could reach and ran it a few days. The leak is from the oil seal where the passenger side half axle goes into the tranny. A lot to take apart to replace a five dollar seal.![]()
