I assume this is a manual transmission? That's pretty rare on a minivan so I thought I should ask.....Input hub shaft has no play after putting the transmission back together.... everything seems to fit right on the side and is all in order....it spins the gears when using plyers.... would it work?
OK, shaft play is indicative of a bad bearing. Many times with the shaft moving around, it gets damaged (the teeth mesh wrong, wear and chip). But, if you have checked all of that, and didn't find a bunch of metal in the pan, it should be ok. I would install it and see what happens.its an automatic... it had play in the shaft before it was taken apart
