I am in the middle of replacing a 10'*20' shed that had a planter built up against it And had rotten the wall. (shed is attached to a large garage). As I was demoing the shed I found that where the shed is attached to the garage it's rotten a bit of the garage corner beam. (can I jack up the corner and replace it?) My question is, the outside of the garage is stucco and I'm putting siding on my new shed. Can you transition from pre poured stucco wall to new vinyl siding? Or will I need to replace the stucco on the garage with vinyl? Cheers
