If bk sees a constant 24v it will allow the fan to run at 100%. 0v will run the fan at approximately 80%. The NEXIA thermostats use a PWM signal on bk to control fan speed from the stat.
With a 2stage unit with a unloading scroll like you have y1 turns the unit on and without a 24v on bk the fan will run at 80%. When the thermostat calls for y2 it will sent 24v to bk causing the fan to run at 100%.
Sent from my iPad using Tapatalk
