I have a 1997 vintage Trane XE80, which would cycle on for heat, Gas burners will light but for only a second or two then go off. The unit has a White Rogers Model 50A50-471 controller, The controller is flashing error code 5: Flame Sensed with Gas Valve Off. After reviewing post on this forum I remove and cleaned the flame sensor, no change. I then changed out the flame sensor with one from a second furnace. Same results.
Does this mean the controller need to be changes?
Thanks,
Thanks,
