The unit is cycling on the high temp limit control. If the furnace sees an open limit control it thinks the furnace is overheated and will continuos run the fan. They need to do a temp rise check on it to see if it is running too hot. Due to a dirty AC coil, undersized ducts or too many registers closed. Reason it does it in the AM is that it is colder and needs to run longer.
