1 - 9 of 9 Posts
I have a Toro Model 20382 self-propelled mower. Is there an adjustment that will allow the mower to push easier? The manual calls out an adjustment “Adjusting the Self-Propel Drive.” It is to increase or decrease the mower’s traction?
If I were to increase the traction, would that allow the mower to push easier? Or, is there another adjustment I could use?
Jerry
I recently replaced the drive wheels on my Toro Recycler II Pro due to tire wear, the tires were worn down to the plastic. I found that the wheel bearing were shot and the inner races were turning on the axle bolt. Replacing the wheels made the mower much easier to push which is helpful for backing up.
I had a problem where I gradually lost traction on the drive wheels. I changed the drive belt which didn't help, and looked all over the Internet to see how to adjust it. I was about to either get a new mower or send it to the shop.
Then I saw the instructions in the Owners Manual. Took about 5 minutes and now works like a champ.
1 - 9 of 9 Posts
