1 - 15 of 15 Posts
My sister has a Condo and she has bought vinyl planking to go over a concrete slab. The rug and tackless has been removed. I don't like the look of quarter round. I like the look of the flooring sliding under the baseboard moulding. It's cleaner. I'm not fond of prying off the moulding, cutting it on my table saw or just moving it higher, I have 4 different sizes of nail guns, taking the chance of destroying or marking the sheetrock though I do know to put a putty knife or metal behind the pry bar, and I have a set of the smaller moulding pry bars besides 2 larger ones.
Is there an electric tool or saw I can buy to cut the moulding? It's a very large living room 20'x25' with an open dining area 12'x15' and hallway 4'x15'.
I don't like the look of quarter round..
I'm not sure if anyone does. Unfortunately every remodel I have ever seen by DIY'ers or professionals has quarter round as the go-to solution.
As I side note, I have ALWAYS taken off the trim on my own projects in my home and I would certainly do that for anyone who wanted it done on their job.
Either live with the look or take the time to do it the other way.
I wonder if the saw that Nealtw shows would cut smoothly or tend to wander as it moves across the floor? I would think keeping it straight may be a problem with hard wood trim and the occasional nail you are sure to run into.
· Hammered Thumb
I use the jamb saw often, and not just for jambs. Easy for plunge cuts, once you start traversing sideways, they are a little bit harder to control. Without a perfectly even surface, and even with, you may not have a good even finish on the cut over that much length. Better to remove the base and use the milled edge on the bottom for uniformity.
Ya' know......
Why does it have to be quarter round? Stop could work and add some character to the baseboard. My wife and I had this discussion a few days ago.
Plenty of decorative trim that is 1" to 1 1/2" that could be put there instead of quarter round.
Might look pretty good at that.
I hate 1/4 round. This is a better option.
https://www.homedepot.com/p/House-of-Fara-3-4-in-x-1-1-4-in-x-8-ft-MDF-Shoe-Moulding-8595/202087600
having said that, I think you should pry off the baseboards and move them up or do the shoe molding. i'm not a carpenter, but I can't imagine you'll get a clean straight cut on the jamb saw for the length of the room. The only beneift of doing that is you could use a smaller molding since you could get the boards under the existing baseboard, and all you're covering is the cut with something smaller like a bead molding
https://www.homedepot.com/p/Ekena-M...PVC-Bead-Moulding-MLD00X01X96BESWPV/309947008
· Naildriver
Remember one thing, your floor is not perfect. Your base only moves in and out, not up and down. Any aberration in the floor will be telegraphed to your base. You will need something like shoe molding since it will move in and out, as well as up and down to cover the crack.
I wanted to add a piece of 1/4 or 1/2 cove trim to the bottom of my baseboards to give it a more finished look on the tile/wood floors, but it wouldn't work due to the angle/slope on the contractor grade baseboard I have :/ Eventually I'll get around to replacing all of the baseboard trim.
I would replace the molding and not worry about damage when removing what is there now. Builders use the cheapest molding they can find and it looks cheap on the walls. Why upgrade the flooring and leave the cheap trim?
Primed MDF or fingerjoint trim is about $1 a foot and a worthwhile upgrade.
I personally distinguish between quarter round and shoe molding. I like the look of shoe molding myself, it's a bit less instrusive than quarter round, and it does solve some of these issues sometimes. But personal preference....
1 - 15 of 15 Posts
