I added two light feeds to an existing octagon box and it's at a point where there are way too many wires to connect all together with a wire nut. It just does not seem safe as it's not as tight as I'd want it to be, and I'm afraid that the wires settle out inside and cause a partial contact which could lead to small sparks and potential burns. A fire hazard waiting to happen.
What is the best way to deal with this? Basically I got like 5 wires per wire nut (neutral and hot). I decided to separate them into two nuts then join them with another wire but then there's still too much to push inside the octagon box, and I don't know if joins like this are to code. Seems kinda hackish.
Should I just get a deeper box and bigger nuts? (squirrels like bigger nuts:laughing
Or is there a better way to deal with this?
There's also a mystery wire in there where it just passes threw, and the white is just cut and left there, so I also need to trace that one out and see wtf they did there. :laughing: The fun stuff you can find in a previously owned house amazes me.
