Heya - I'm trying to replace my toilet water supply valve which is connected to a copper pipe via a compression ring and nut. But its stuck - I can't unscrew it and there is some blue/green copper corrosion in the threads of the valve that lead into the nut (the nut rotates on the copper pipe but I can't unscrew the valve from the nut). I think the corroded copper is making the threads stick and impossible to turn the nut to remove the valve.
I've tried WD40 and no luck. Now I've sprayed a solution of vinegar and salt onto the threads to try and eliminate the copper corrosion but it doesn't seem to be doing anything - I'm not sure it will seep deep enough into all the threads to have an effect anyways (will leave it overnight and see).
I'm afraid to try and hack-saw the nut as I'm not very adept with a saw and it will probably take until doomsday to cut the nut. Is it okay to just cut the copper pipe at the edge of the nut? I think it will be easier for me to cut copper. There is a good 1.5 inches of copper pipe sticking out of the wall up to the edge of the nut. The new water supply valve comes with a new nut which has a copper ring inside. If I cut the copper pipe do I just slide the new nut over top of the pipe then screw the new water supply valve into it?
I've attached a photo. If anyone can give me advice on the best way to get this old valve removed I'd appreciate it (I'm trying to connect a Bidet attachment which requires a different kind of valve).
THANKS!!
THANKS!!
