How will putting the vent pipe approx. 4 feet down stream from toilet effect it?
jburd964 · Registered Joined May 4, 2009 · 265 Posts Discussion Starter • #1 • Jan 14, 2013 How will putting the vent pipe approx. 4 feet down stream from toilet effect it?
Javiles · Master Plumber Joined Dec 12, 2011 · 1,615 Posts #2 • Jan 14, 2013 Depending on how your setting up your venting wet vent / wet bend / if allowed by your code, you should be fine if within 5 feet of the W/C
TheEplumber · Premium Member Joined Jul 20, 2010 · 11,716 Posts #3 • Jan 14, 2013 jburd964 said: How will putting the vent pipe approx. 4 feet down stream from toilet effect it? Click to expand... Assuming it is a properly installed vent it should be fine
