I could have sworn I had posted this same issue on this site but cannot find the thread in my user cp?
Anyway, this old toilet in my basement has a very strange problem, how this is setup is like this, the toilet bowl is situated on top of a small tank which has a pipe in the middle of it leading to a sump pump located close to the tank so the water from the tank goes down the bowl as per normal and into the tank under the bowl then into the sump pump basin.
Problem is every now and then after flushing and the tank is emptied and the flap which covers the tank hole gets stuck becuase the chain gets tangled up, the running water is leaking somewhere under the floor so I can't understand this. Whenever a flap gets stuck the running water is supposed to go down the sewer or in this case into the tank under the bowl right? I really have no idea how to see exactly where the running water is leaking? Or shouldn't there be some new tank system nowadays which does not have any flap problems?
