I have read 3 pages of threads talking about toilets that are not completely flushing and nothing is helping. Maybe I need to specifically ask my question for my specific issue.
I have a Kohler toilet with a siphon jet at the bottom. When I flush with a full tank, ( to the top of the overflow tube), the water flushes out the siphone jet and anything in the bowl at or below water level goes down the drain slick as a whistle. The Rim jets however have No water coming out of ANY of them, dry, barron, free of water.
Anything above the water line, usually tissue, hangs out and never goes down.
I Inspected with a mirror and fingers and no rough surface. No calcium or lime build up. If there was something, I would have thought that I would have gotten at least some water out one of the holes.
About mid way from the water line and the rim, at the front of the bowl, above the siphone jet, is a hole that water does come out. But as I repeat, no water out of the rim jets.
I poured Lime-A-Way down the over flow valve so incase I missed, the tank would dilute the Lime-A-Way so it wouldn't damage the flapper and fill valve. All I got was a bowl full of Lime-A-Way. I let that sit for an hour and still nothing.
I removed the tank and inspected the inlet opening, with a mirror and hand I did not find any obstructions.
The only other thing is to remove the toilet completly and turn it on its nose so that the Lime-A-Way would stay in the ring and not fill into the bowl. Would that be the right next step?
If so if I remove the toilet I have to replace the wax ring correct, it can not be reused with the same toilet?
Anything else I can try before I pull/replace the toilet?
