My first time replacing a toilet. Removal of old one went fine. Lowered the new toilet onto the flange bolts and ran into two issues:
1. The toilet went readily right to the floor. I had expected it to sit on the wax ring, and thought I'd have to push down to get it flush to the floor. But I didn't feel any resistance on the way down so I'm worried that the ring didn't seal properly. Maybe I need a double ring? I'm confident that the toilet aligned properly on the discharge hole (judging by bolt placement). Should I have felt some resistance due to having to push down the wax ring, or is it normal that the toilet would easily settle to floor level?
2. The toilet isn't level -- it slants side-to-side by almost a half inch. The culprit is the floor, which I now see is slanted by that amount. I could shim one side of the toilet, but I'm afraid if I lift it up I'll break the wax seal (if there is a good seal). Also it would look lousy to shim one side that much (it's the visible side that's lower). Will a half-inch off level cause a problem with the flush? Maybe I could shim a quarter inch as a compromise? (Would lifting the toilet 1/4" break the wax seal?)
Thanks for any help.
