Toilet Flange Questions (w/ pictures)
OK... took out old toilet a few weeks ago as part of bathroom remodel, now in the final stretches of putting back together :thumbup:. We did not replace the flooring, and we are on the bottom floor of a condo building (so no access underneath, piping hard/impossible to access). Hoping to get some advice on this.
I have my new toilet, wax ring, etc ready to go, but want to know if I need the flange replaced or not, and also if its in good condition. Also wouldn't hurt to know the various part of it. :wink:
Below is an overhead look. I've color coded various areas so you can compare to second picture below...
This is a side profile. Colored areas match up to first picture...
Here are my questions by color:
Red Arrows/Box: this is where the previous toilet screws/bolts were, and where the new ones need to be to line up... does that look correct? The bolt just slides in like that, nothing holding it in from the side? (I left 1 screw from the old toilet in on the right side)
Yellow boxes:: small "dimples"... two of them on opposite sides... not sure what they do? Place for wax ring to settle?
Blue ovals/outline: this is hard to tell in pictures, main reason for the side angle I took. They are random ridges around the inner edge of the flange. Honestly, it looks like there originally was an entire "lip" all the way around, but only there in pieces now.. like it was broken or chipped... is this correct? If so, does this mean I can't install a new toilet on this?
I'm also assuming that rust color inside the pieps (appears cast iron) is OK and not to worry.
The main overaching question is: can I proceed with the new toilet
whistling2
at this is or consider replacing this, or getting one of those flange fixer things I've heard about on here? Also, if I am using this flange as is.. you think I need to get ALL the wax off or its in decent condition now to make the seal? Thanks in advance!
ONE THING TO ADD: also noticed the flanged isn't "screwed" into the floor/subfloor... but it is solidly not moving... issue?
