Hi,
I'm on a concrete slab and have an offset flange. The previous owner had the toilet cemented, grouted in place. Yes, it was a complete disgusting mess when I got it out.
Anyway, I'm going to be installing a Kohler skirted toilet so it does not need the flange bolts to hold the toilet in place, but will utilize lag bolts to hold it down.
The flange is in really rough shape as you can see from the images below. While trying to remove one of the flange bolts (it was cemented in also) I tapped it with a hammer to loosen it a bit so I could rotate it and lift it out, and a whole section of the flange fell away.
What are my options here? Will I still be able to get a wax ring to seal on this? Any advice at all is welcome. Also, as you can see, I am about to start tiling, I imagine I should hold off on tiling that area in case drastic measures are called for.
Thanks in advance!
Karl
Thanks in advance!
Karl
