there is a little tube inside the tank coming from the ballcock (fill valve) that needs to be in
the overflow tube. that is what refills the bowl after a flush. either yours is not in the right spot or it is clogged at the fill valve.
instead of flushing twice just hold the handle down a little longer so more water goes into the bowl.
make sure the water level in the tank is at the correct height.
