I need to patch an area and put a new sheet of drywall in a room. Problem is, the studs have nailheads sticking out on the face/front, from toenailed nails going into the bottom plate. I tried knocking the nail heads with a hammer so they are inset into the studs, but can't get them inset all the way. They are sticking out a bit.
Any tricks to getting these toe-nailed nail heads inset so I can drywall over them or doesn't it matter if they stick out a bit? Will the drywall just "absorb" the nail heads as I screw it into the studs ... or will it stick out in those areas?
