My home currently has a Bard oil fired furnace and Goodman forced air central AC system. The Bard furnace is about 25 years old and the AC system is 20 years old.
I just had a tech from a local Trane dealer out to give the system a preventative maintenance checkout prior to the start of summer in a couple months. During his visit we discussed a new HVAC system.
The furnace works well for it's age. The blower motor needs a new capactitor; a $20 part that I will replace if needed. The AC system is 2.5 tonnes and the outdoor compressor motor(not the fan motor) makes a noticeable bearing noise in operation.
The house is 2800 square feet, 1.5 stories with lots of windows, and a finished basement. We have to operate a portable dehumidifier in the basement during the warm weather months. We also have to install a window AC unit (10K BTU) in the upstairs bedroom because the current system can't keep the upstairs cool if the outside temp is over 75F.
If the outdoor temp is over 90F, then the system won't hold temperature below 78F indoors in any part of the hourse. If I set the thermostat to 76 or less when it's really hot outside, the coil freezes because the compressor never cycles off. So in the peak of summer we've kept the thermostat at 78-90F during the afternoon. After sunset we can cool the house down to 76 or so.
It's $10K for a new 16 SEER Trane heat pump and oil fired backup furnace. 5 years zero percent financing. We don't have natural gas service available, propane is $$$, and I just spent $1000 to replace the outside oil tank because the old one sprung a leak last summer.
Am I smart to replace the current system before it fails? Or should I continue with what I have? I have to buy a new window AC unit($300) for upstairs if I keep what we have.
I'm trying to get a feeling for how much money a new 3.5-4 ton heat pump is going to save me over the current 10 SEER AC unit. Our electric bill runs $350 per month in the summer. But we have electric hot water and clothes dryer adding to the bill...
Any advice from others who have made this upgrade, or professionals who have seen the before and after from this type of upgrade, is welcome.
