there are many different PSI washers available and there are different tips you can use. just dont use a 0 tip and dont get too close to the fence with the wand.
the hotter is is the faster you have to work. try to work in the shade when staining and keep a wet edge. if the material dries and you overlap you will get what we call a "flash mark" - meaning that the material will be shiny in the overlapped area. when you can see Flashing in exterior stain you know that someone that doesn't know how to paint did that job.
