Hi All,
So the age old question of basement flooring...To layover or NOT to layover ?
I have 1969 Parquet flooring in good condition, dry no mold, some squeaking. Time to remodel the basement. I purchased 12MM-LAMINATE FLOORING MEGALOC Mono Serra. Layers: foundation then plywood and then glued parquet. Do I screw in noisy parquet, install underlay then laminate flooring? OR Do I remove parquet then install underlay then install flooring? Again no visible damage, no mold, no musty smell in Basement. Seems leveled.
What to do? Any advice ?
Tileguy
Wait....... You had installed real wood parquet below grade over plywood, and it's still working for you? I think you have been lucky.
I don't think there's a wood flooring manufacturer that thinks that's a good idea.
Regardless, I think you need to remove it and review all the installation instructions for your new flooring.
Jaz
Reactions: Montreal_Guy
Discussion Starter #3
I guess back in 1969 they had a different way of doing things. yes, everything is fine no bubbling, no mold nothing other than some squeaking, all below grade. Thnaks for your feedback Jaz man. Grazie!
Tileguy
Prego, Montreal Guy.
No, they did not have a different way to do things in '69. But you can do things wrong and it can still work fine.
Jaz
Your floor was installed when it was known water doesn't soak through concrete like a sponge but rather can condense moisture on the surface under the correct conditions. It seems that people has gotten dumber than dumb and now plastic is usually recommended.
