Hello everyone. I am in the process of renovating a house and am going to upgrade the main panel. The new panel will be a Square D 200 amp, 42 space, ground on neutral panel.
I feel pretty comfortable doing the work myself, but I have some questions. I'm sure that some of my questions are super basic. Maybe they all are. Here are my questions thus far.
1. I've seen examples of very neat work inside panels where like wires are bundled and even zip tied together. Is this a good idea, or does bundling wires create excessive heat?
2. How much thought do you put into trying to balance the load on the two hot bus bars? I have read things that say it's important, and other things that while not saying it is unimportant, suggest that most residential loads aren't big enough to create a big problem. I don't know who to believe.
3. The panel is in a utility room. The conduit to the panel comes down from the attic through a stud bay, and the panel is recessed. The distance from the top plate to the panel is greater than 12". Do you tack a 1x piece of wood between the studs for securing the cables? A 2x won't fit, because of the conduit. I've thought about cutting the conduit and mounting the panel higher, so I wouldn't need a cross member for the cables, but that makes the main breaker feel kind of high to me. Although it isn't higher than is permissible. Any thoughts?
These aren't all my questions. But I don't want this to get too long. Thank you very much for any thoughts.
Leo
Leo
