Lacquer Thinner - The best cleaner for old brushes or brushes that have harden paint. I also use it every so often to deep clean clean brushes.
Be careful, it's potent, wear glasses, do not use near a flame, do not use where there is a furnance, use in a ventilated area. It also evaporates, keep the cap on. DO NOT fill to the ferrule. The LT will dissolve the glue that holds the bristles. It's reusable, filter through a funnel with a paper towel as the membrane. I use a wire brush immediately after to clean the bristles. It starts working immediately. You may only need to let the brush sit for a few minutes, sometimes longer, sometimes periodically pulling the brush out to use the wire brush before putting it inn the lacquer thinner again.
I do not use this everytime! Only as necessary.
