1 - 9 of 9 Posts
Cement pad exists for 50+ years in a covered breezeway leading to my front door. I live in an area that rarely gets 25 degree weather for more than a week, usually mid-30's and above--and this is a protected area. It's cement gray-color. I'd like to make it a light terra cotta, but not really change the texture or re-do where the cracks have been filled over the years because as it stands would give it a more antique look. It seems pretty solid as a surface. Is there some way to do a "wash" over it? Even a few times, to get some good color on it without changing it's texture? I think painting it would give the wrong look altogether--too solid, not enough "movement." It's a bit rough to the touch, which is good, not slippery. I think it was covered with an indoor-outdoor rug which was not glued down for years.
There are(were) concrete stains, haven't used one in a long time. Check a local paint store or even a tile or concrete store. You will need to figorously clean the concrete, and probably an acid wash(muriatic acid) is needed. The stain has a mild acid that needs to be mixed in, follow directions carefully.
The acid staining site , (thanks, Willie T) seems to have all the info I need.:eek: I was astounded at how complete it was. So, come end of summer, cocktails at my house! I'm sure I will have finished everything outside :laughing: by then.
Sorry, I couldn't help but use those silly icons.
Old School
It literally tickles me whenever I find a site like that where someone really tries to do a job the right way, and "bares all" in the telling.
Old School
I have trouble finding sites--was it on this DIY chat? I couldn't tell from the link. I did find a beaute for inexpensive (i hope) and creative fences . Pass it on if you'd like. http://www.ro-lu.com/
I've found you can find a world of neat ideas on GOOGLE.... but you need to hit <images> after you have Googled a particular subject. Muchly cool way to search.
1 - 9 of 9 Posts
