1 - 8 of 8 Posts
I'm going to put on a new tin roof over the old shingles , the roof is 15'x40
the sheets i can get are 8' and 12' but i need to go 15' so i plan to put a 12'and 4'this will let it the 4'lap the 12' one foot , do i want to keep this seam
the same across the roof or stager the seam by putting the 4' on top then on the next row put the 4' on bottom then back on top for the next . what do you think?
You do not have to stager the seams. 1' is a minimal overlap, I always go at least 2'. But I wouldn't put it over asphalt shingles or shakes. The metal gets very hot and you could set the roof on fire.
In N.Z we use metal roofing a lot We also have extremely hot summers, up to 40deg celsius. As an underlay to the roofing we use a tar based paper. As a volunteer fireman I have not seen a fire started by this manner.:thumbup:
1 - 8 of 8 Posts
