Hi folks,
First time tiler here, getting ready to lay large format (12x24) tile in my upstairs bathroom and encountering a layout challenge. We want to lay the tile with the long side parallel to the long side of the room, but the spacing leaves roughly a 2" gap (would be about 1.5" after leaving a 1/4 inch expansion joint on both sides of the room) that would be very difficult to fill in. The attached picture illustrates what I mean.
I will be putting in base trim later which would fill part of the gap on the non-tub side, but no trim I've seen is 1.5"+ wide.
One possible option here is to place four rows of tiles oriented to the centerline of the room, but then I'd have to cut roughly a 6.5" x 24" strip to fit along both sides of the room. I'm not sure either how that would look or if it violates any kind of code for the area along the side of the tub or behind the toilet. There also may be an issue with our new vanity, since the two rear feet would sit directly down on this narrower strip of tile. Again, I don't have the experience to know if that's a problem or not.
Any thoughts on the best way to deal with this layout challenge?
