Hi all, new to the boards and wasn't sure if this should go here or in the remodeling section...
I have a boring "builder grade" ceramic tile fireplace in a home I am buying built in 2000. I want to remove the large beige tiles and replace them with some subway tile, some mosaic, or some of the metal or metal-looking tiles. Something with some color and something that looks interesting. I'm not sure yet. Two questions:
1. Are there certain types of tile that are not safe for putting on a fireplace? Is there a specific "type" I need to look for that can handle the heat? The fireplace also extends to the floor (I think this is called a hearth?). So whatever I go with would have to be fine for both.
2. I just assume that whatever the ceramic tile is affixed to, it's fine for me to clean up/patch,etc what is there and just re-tile right over on top of that. Accurate?
Thanks, DIYers - much appreciated!
TB
Tileguy
TB
Well the first thing is to show us a picture and the next thing is to know what's below the existing tile. Heat on a fireplace surround isn't usually an issue, why is it now?
Is this a wood-burning fireplace, gas, electric light bulb, what?
Hi Bud, thanks for taking the time to respond.
It is a gas fireplace. As far as why heat on a surround would be a problem - I don't think it's a problem - I just don't know if there are certain tile types that should be avoided when tiling a fireplace - I don't know these things, sadly.
Here's a picture:
Never heard anything one way or the other regarding metallic tile, except that some people do it and don't report a problem. But other than that, pretty much whatever you want. Ceramic/porcelain tile was formed in extremely high heat - the puny heat of a fireplace surround is like a warm spring breeze to them.
Tileguy
Not a problem, any tile you choose will work.
