Hi there,
We are planning on applying/installing porcelain or ceremic tiles on a cement base. The area is located next to out garage and its nearly (12ftx8ft) in area. The area use to have a green outdoor carpet glued to the floor. Here are my questions:
a) We have taken out the glued carpet and the foam/rubbery material under it but we are not sure if we need to clean the surface more or its good to go for installing tiles. Please find the image 1 attached for your reference.
b) There is a crack in the cement that goes all the way across the area and through the garage. I am a little bit concerned about this being a structure problem or its a normal wear and tear for an old house. Please find image 2 attached for your reference
c) There is a 1/2inch gap between floor and the wall. I am planning on putting expanding foam and caulking but I am not sure if this is correct way to fill the gap. Many articles on internet suggests not to block it/cover it because it was left there for cement to expand.
d) We are planning on putting a waterproof membrane on the cement floor like this one (Waterproof-Floor-Uncoupling-Mat-Underlayment-CI-5m-B/304276429) and then just laid out the tiles on it, is it good enough or we have to do use some other materials in between to keep the flooring safe from moisture.
Any advise is highly appreciated. Thank you
