Long explanation - one simple question:
I'm thinking of putting ceramic tile in our two bathrooms...they currently have like just one sheet of vinyl on the floor - figure that will come up easy enough...The house is probably 40 yrs old, so I suspect the subfloor is probably plywood...I'm thinking that since there is not much space to do (probably 40sqft total between the two) I would put down concrete board - whatever that stuff is called - to make the floors nice and stiff for the ceramic...finally, here is my question:
If I put down the hardboard and then the mortar and then the tile,seems as tho my floor will be about an inch or so higher than it was - so what about reinstalling the commode? Will a regular wax ring seal up? Do I put two wax rings on top of each other? Something else? No problem? I don't wanna do all this and then have a problem getting the john to fit right...
What did you do?
Architect / Carpenter
Wax rings come in different heights, and can be doubled up if necessary. It's a common issue and the exact solution should present itself once you get the floor installed and can identify the final height difference. Good to be thinking ahead!
Retired Moderator
Tile backer add no strength to the floor system ,just an ideal surface for bonging tile---so use 1/4 inch thick.
Put cement based thinset under the backer to fill any voids.
