I have a main drain (septic) that comes into crawl space thru wall @ 10 in off the ground and @30 in under the joists My stack drops thru floor @ 3ft off to the side of the drain axis. So I have to offset the stack over to the drain and then tie it in. I would prefer to keep the offset for the stack tucked right under the joists (so its tucked up out of the way - it's right beside my access). Which means my stack will turn 90 deg towards the main drain, run @ 3ft to where it reaches (crosses above) the main, then 90 deg down to tie into it.
Is this acceptable?
Can I just use standard 90 deg elbows for the 2 bends in the offset (across and down)?
How do i tie the last short "down" section of the stack offset into the drain? I'd like to drop the stack into a tee or a wye at this point as opposed to another elbow as i could then add a clean out right in the end os the drain. Does this make sense?
Is this acceptable?
