Check out the Sensi T/S --------
I looked at the Ecobee and was really considering it but everyone complained about the same thing, the touch screen is not responsive and sometimes it locksI'm not overly wild about nest. It's a work in progress and getting better but it still has its quarks. It most definitely is a good looking stat and if "pomp and circumstance" is what you're looking for then who am I to shoot you down.
Honeywell is a real work horse in my book (and I prefer it), but I guess it comes down to what kind of heating system you have. If you have a plain jane furnace/ac then any one of those stats will work for you. Ecobee is probably the best balance point between "pomp and circumstance" and "work horse" and a good fit for a plain jane system.... it's also a pretty consumer friendly install. In fact if plain Jane... I would seriously think Ecobee
If you're running a heat pump with aux heat (especially heat strips) then I wouldn't bother with any of those stats and instead jump up to the Honeywell Prestige 2 IAQ system. A heat pump can save you lots of money if controlled properly, and cost you a lot if not. The IAQ goes deep into depth and detail in level of control that I have not seen on any other stat. It's redlink system also lets you customize and add on other features. It also gets you around the dreaded lack of "C wire" issue that many have. The stat only requires 2 wires instead of the standard 4... 6... 8...
On the down side it is slightly more complicated to install and Honeywell does not like diy'ers installing it and won't be too helpful if you have a problem.... but that's why sites like this are so good :smile:
http://www.ebay.com/bhp/ecobee
http://www.ebay.com/itm/Honeywell-YTHX9421R5127WW-Prestige-IAQ-Thermostat-kit-with-Redlink-/131565805671?hash=item1ea1eee067:g:Ge8AAOSwT5tWOCKl
Thanks, sounds good but the appearence to bland. I want something with a wow factor. Color screen, options, five day forecasts etcCheck out the Sensi T/S --------
