1 - 7 of 7 Posts
I have a thermostat that controls baseboard heating. I have removed the baseboard heaters and would like to use the wiring for the thermostat for an outlet. Is this possible?i hooked it up and everything i plug in doesn't work anymore. too much juice i guess. is there a way i can do this?
Well that's one way to burn your house down.
Time to call in a pro.
Most baseboard heat is 220 volt, no nutral, by doing what you did may have made a dead short.
Reactions: DexterII
· Super Moderator
The baseboard heaters are operated at 240 volts. When you connected a receptacle and plugged things in you applied 240 volts instead of 120 volts.
To make this function properly you need to change the wiring in your breaker panel so this circuit has a 15 or 20 amp breaker controlling it and is set up for 120 volts.
1 - 7 of 7 Posts
