I posted about this leak before (last fall). The northeast corner of my garage sometimes leaks. It only seems to happen during wind driven rain. I have tried everything (in my opinion) to find the source from where the water is getting in.
- I removed a section of drywall right above the leak area. The insulation, exterior sheathing, everything, is bone dry.
- Last summer, I removed the first 3 courses of exterior bricks at the affected corner. I thought I found the culprit - there was a small hole in the waterproofing membrane. I replace it and added blueskin and put everything back together.
After all that, water is still getting in!! I don't think it's an issue of the eaves over flowing into the soffits because this only happens when it's raining in high winds. Normal rain doesnt cause leaks.
As you will see in one of the pictures, you can see exactly where the rain hits the house and where the bricks are water saturated.
Could the water be getting in through the weep hole? Even if so, the blueskin should keep it from getting in.
HELP??
HELP??
