i can never keep'em straight but this one is a 240 volt one.the one with the " T " on the other side is 120 volt 20 amp type. not as common as the 240, as the later is a duplex.:thumbup::thumbup::thumbup:
The manual shows that charger with power entering through the top. That doesn't seem optimal for your installation. You'd need to install a post to mount it on, and run conduit up it, then back down into the top of the charger. You may find a different charger that would fit better. They make a post mount for that charger, but it's $700.thanks mpoulton. I see what your saying. can I just run the conduit outside to the evse half way down drive way directly? I see some folks use conjunction box next to it. is that necessary? I was looking at the Clipper creek lsc 20. it says for outdoor, I'm just worry when the rain comes.thanks
Those are both good reasons not to be doing this at all.Reasons for not going larger.
He is renting and shouldn't be wiring himself.
The main is a FPE stablok panel.
http://www.diychatroom.com/f18/can-someone-shed-some-light-my-panel-363209/
Yikes, good catch Oso954 of cross referencing the posts. I would not touch that panel either because of FPE. A renter should not be doing work on the panel, he should be talking to his landlord about it; which is what we so far agree with.Reasons for not going larger.
Also, kbb1 this statement is telling me that you may be biting off a bit more than you can chew with this project. If you don't know that you don't need to use a neutral with a 240 circuit then don't attempt this. So far you have not listed the actual charger you are planning on using, you have just stated "I was looking at the Clipper creek lsc 20", you need to know which one you will be using (according to what is required) and then run the proper lines. I have seen 20 amp (need 12 gauge), 30 amp (need 10 gauge) and 50 amp (need 6 gauge) chargers. The amperage will determine the gauge wire you will need. Don't even try using a 12 gauge with a 30 or 50amp charger.thanks circuitman. upon opening the outlet to check the wire for juice with the volt pen. the wires were pulled but never hooked up throughly. lol I dunno the reason why but the breaker is in place and it seems like they pulled 12-3 wires as I see red.black white and bare. so do I just cap off the white? or leave it alone as I will hook it up tmrw when I shut off the panel.
If this will be exposed to rain or wet location the breaker should be a GFCI.I'm just worry when the rain comes.thanks
Voltage does not determine the gauge of the wire needed it is the amperage.#12 is pretty stiff wire , as 14 is easy to bend.if you have a wire stripper that will tell you. if it is straight 240, you can use a 12-2WG you have to reidentify the white wire with black tape as it is now a hot wire.:wink2::wink2:
