Hi all,
Here's my dilemma. I really want to install a double slide-in-wall door, like the attached image. However on the same wall , I must also also install light switches close to the door opening. Because the door slides "into" the wall, using normal 2x4 framing walls, the pocket inside the wall would not allow any standard electrical boxes (in order to install a light switch there) to coexist inside that pocket as this would block the door's sliding path.
I'm guessing I could always make a 2x6 framing wall, but I prefer not to add extra thickness to the wall if possible. Therefore I'm wondering, if I stick with a 2x4 framing wall, is there such a thing as super thin electrical boxes? or anything else that can get around my problem? Thanks!
