I'm weighing the options between making my own concrete pavers or purchasing them. The problem with purchasing is that the dimensions I need don't seem to be available, or if they are they're a bit too expensive (well, to me anyhow).
My questions right now aren't about whether I should make them or not...just a few clarifications on the process of making them.
First some info:
I live in Austin, Texas - so freezing is not really a huge concern.
We might get two or three nights of freezing temps every year at the most.
The pavers I would make would be about 23.25" x 23.25" and would be 2.25" thick.
I plan on laying these out to create a patio in a grid pattern with bricks running between the pavers. (we already have paver bricks, which is why we're trying to incorporate them into the patio).
If I do decide to make them then I'm going to mix my own concrete (or mortar)...which brings me to my questions:
1. I've seen posts out there that suggest I only need to use cement and sand. I've seen others that say I need to use some aggregate in the mix as well. Any thoughts? (this patio will get foot traffic, but no vehicles or anything like that).
2. I've also seen posts and pages suggesting that if you mix with a 2:1 ratio of cement to sand you will not only get a smoother finish, but you could unmold your pavers within an hour or two instead of 24 hours later. Is that true? If so that could make the difference between deciding to make them myself or not - simply due to the time involved.
Any advice, info, etc is greatly appreciated.
Thanks in advance.
First some info:
Thanks in advance.
