Hello,
we currently have a storm and the heat pump is completely frozen inside out. The whole winter it has been building up snow and ice. Yesterday the thermostat screen went blank, I checked the sum pump as some people told me if the water is clogged it will shut down the unit.
Finally, decided to go check the heat pump outside and there was a thick layer of frozen ice. Check the picture its nothing you've seen before (maybe). We are currently freezing so we bought a few little heaters, but we need the unit back on.
the picture cannot be embedded please paste this to your browser: imgur.com/a/DeEBu7P
What can we do to remove the build-up of the ice inside the heat pump?
Currently, I removed all the ice from the outside. The fan which is on top also had a thick layer of ice.
