1 - 8 of 8 Posts
I've just purchased a new Goodman heat pump and Air Handler. The air handler has a ECM fan motor and the brochure says the fan speed is variable. I'm guessing with the Comfortnet thermostat which costs about 379 dollars. It is a touchscreen etc..
I am wondering if there is a plain non-touchscreen thermostat I could buy with same programming capabilities as the Comfortnet thermostats costing alot less than 379 bucks.
Does anyone have any info to share?
Appreciate the help.
You will need Comfortnet thermostats (ctk01 ,ctk02, ctk03) only if you have communicating control features. You don't need these tstat if you system uses R,W,Y,G wires. The ECM motor still will be variable speed.
· In Loving Memory
Only the Goodman communicating thermostat can control the fan speed directly. Other stats can send a signal to slow down, but not control the actual CFM.
Comfortnet features
Only my Air Handler has the Comfortnet features. My outside Heat Pump unit does not. I am trying to find a cheaper alternative to the Comfortnet "touchscreen" thermostat.
I'm also wondering what features I am missing by not having the Comfortnet communications for the heat pump unit?
Anyone have any ideas?
· In Loving Memory
If you rewire the thermostat wires at the furnace you can. Your thermostat should still be under warranty.
1 - 8 of 8 Posts
