So my son tried to give me a hand by swapping the new Hunter 44905 thermostat for the existing Carrier TSTATCCPLH01-B thermostat while I was at work. The problem is that he removed all the wires before labelling them and then panicked when he realized that he needed to know them for the installation. When I got home I was able to at least determine which wires went into which group by the way they were bent. Not sure if there is an easy way to do this, but it is getting chilly in the house without the heat pump running. Here's what I know...there was a black, gray, pink, brown, and blue wire connected to a group labelled as C, DHUM, HUM, B, S1, & S2. The other group was a yellow, white, red, orange, and green going to a group labelled O/W2, Y1/W2, R, G, Y/Y2, & W/W1. Is there any way to figure this out? The new thermostat has a place for R, Y, G, L, O, B, A/E, Y2, C, & H.
Thanks in advance!
Kevin
Thanks in advance!
Kevin
