Hi All,
I am replacing a wall thermostat for a Cadet wall heater with a programmable thermostat. My box has more wires than I was expecting - I need advise on how to hook it up.
The box:
2 black wires coming from the top of the box (electrical supply)
1 black wire coming from the bottom of the box (heater)
2 white wires from the top
1 white from the bottom
2 ground wires from the top
1 ground from the bottom
New thermostat:
1 black L1 wire
1 red L2 wire
1 black load wire
1 red load wire
Neither the box or the new thermostat have a green screw for the ground wires.
Previous setup with old thermostat:
Black top wire was connected to top black wire
Black top wire was connect to black thermostat wire
Red thermostat wire was not connected to anything and looked burnt
All 3 ground wires were connected and one was connected to green screen on thermostat.
Per instructions for the new thermostat:
Connect black wire from the top of the box to thermostat black L1 wire
Connect white wire from the top of the box to thermostat red L2 wire
Connect black wire from bottom of box to thermostat black LOAD wire
Connect white wire from bottom of box to thermostat red LOAD wire
Connect all ground wires.
Questions:
Is it okay just to have all of the ground wires connected and not connected to a green screw?
What do I do with the extra wires?
- Black from the top of box
- White from the top of the box
Thanks for the help!
The box:
New thermostat:
1 black L1 wire
1 red L2 wire
1 black load wire
1 red load wire
Questions:
