1 - 8 of 8 Posts
Hey guys, New here. My Thermostat has been giving me trouble since yesterday, it will randomly go blank, no letters or lights or anything. I've found if i go outside to the Unit and switch the outside breakers off then on. That turns the thermostat back on and everything will work smooth, for about 3 hours, then it will do it again. And the T stat i'snt battery operated, it run off power from the wires behind the T stat. When the unit kicks on it heats the house find and works good, no strange noises coming from it or anything. Any thoughts??
No expert but I would replace stat and see what happens. If it contionues, then I would say you have a wiring issue and or power issue to stat.
Hopefully some experts will chime in soon!
Thanks,
Ed
· In Loving Memory
Is there a condensate pump on teh furnace. if so, is its safety switch wired up.
1 - 8 of 8 Posts
