1 - 16 of 16 Posts
I want to replace a White Rodgers mercury thermostat. I have heat pump AC/heat with two stage heat and 1 stage cool. I called Honeywell for advice on what model to get and they say I need to read off the letters on the t-stat. Well, there are NO letters. I removed the cover and there are 3 wires on the left side and 2 on the right. No letters anywhere near the wire connections. The model is 1F58-94 and I can't find that model White Rodgers t-stat on the web anywhere. the closest I came was 1F58-72 but it is not identical. I was hoping to find the letters on the instructions. The letters are on the wiring diagram for the 58-72 but who knows how similar they are. The house was built in late 2002 so I don't know why the model can't be found online.
Is there any other way to identify the letters for the wires so I can determine a programmable replacement model? The wires have weird colors too. Light blue, tan, yellow.
you can check the wires colors at furnace board control
can you post some pics?
Discussion Starter · #8 ·
Current White Rodgers replacement would be 1F79-111 (non-programable) or 1F72-151 (programmable) in the 70's series product line. You can probably cross to to another brand if necessary....
I want a 5-1-1 or 7 day programmable. Someone told me Honeywell was the best. I don't know. How would I find the equivalent. Am trying to attach photo for JJboy. Hope it works. If not, will try once more.
Discussion Starter · #16 ·
Thanks to all of you. The slotted screws, all except one, have wires attached. I will give this a try tomorrow, when I have lots of daylight to work with. And hope that I can get it all back together! Yep, I know to keep notes about the wire placement, etc. Thanks again.
1 - 16 of 16 Posts
