1 - 2 of 2 Posts
I have a '90 Thermo-Spa Townhouse hot tub. Over the years I have repaired most everything on it so it is running fine. But the cabinet is rotting away bad. I would like to start rebuilding the cabinet. As a starter, since the bottom board is all rotted away, I was wondering if I can support the tub from the lower middle section by lifting the tub up at the edges, and then putting blocks around all sides. Then gradually take away the side panels and
lower the tub onto its middle.
Then start framing!
Fred
1 - 2 of 2 Posts
