Yes here.Intro shows Toronto. And pictures help.
Bud
Can be the vent channel?Definitely looks purpose built, but what?
What do you see from the attic, be careful if it is just covered with insulation?
Bud
It's so well hidden, the home owner can't find the door.:wink2:Panic room?![]()
Yes, it didn't cover much area, I just curious what it is, and there is unknown block in bedroom。。。It looks like there was an elevator.
but this time it useless. I think you can't reconstruct this area or you can't make it useful.
it may use a small storage area.
but why are you bother this? it's not to cover many areas.
so relax
thank
Thanks.A reason for investigating is (assuming you are in a heating climate) eliminating a potential thermal bypass. Unknown what the construction is like in there but open cavities between floors or worse between basement and attic can be extreme sources of heat loss. I can judge until we get pictures but i have discovered large and small and extreme is a mild description.
Bud
