21 - 24 of 24 Posts
New developments:
I've been advised to switch around the couch so the back of the couch is to the center wall. That would make the fireplace more the center of the living room, as it should be, per many sources I've read from internet (and I'm totally expecting a comment or two about not believing everything you read on the...)
I'm also thinking of buying a couple concrete tables to line the back wall with (120" worth), and accent by setting a slab of beautiful rich wood across.
Here are some new photos that may give perspective.
(Concrete tables will swap locations with couches and couches will line up with the wall where you see the small black table)
I didn't see your post until today, thanks to leenabug. I think the texture aspect is interesting, so I'm sure the concrete tables will look good with wood. It just seems to need color.
It's hard to imagine the furniture rearrangement. Is that for Feng Shui? The photos before showed the details, better.
What have you decided to do?
You want orange for the vibes...
https://www.elephantstock.com/produ...MIq_ONspqg1wIVCjFpCh2rlQiXEAQYASABEgJO0_D_BwE
this might be more your style...
or even this...
https://www.google.com/search?q=ora...r44MKHRAtBWwQ9QEI_AEwAw#imgrc=2UVeIh1lbp71nM:
I just googled orange 3 piece wall art. With the pieces i think taller rather than wider behind couch. Far as the hall, art yes but sculptures might be too big for area...Something to wrap around? The mirror idea with the disco ball or crystals (since you are into positive energy) with some sparse metal decor (get some color) and viola!
Good luck!
21 - 24 of 24 Posts
