This lamppost in front of my house I have been off and on trying to get lit for some time now. This is the closest I've been i have found out where the wires lead. By the front door there are (4) switch panel for porch light lamppost living room receptacles and hall light. The only way I see power getting to this lamppost is by the next switch. As I follow the wire down to the basement it gets connected from white 14/2 to grey 14/2 which I believe is a underground cover type. This leads into a conduit pipe runs along front of house into the lamppost. Now I didn't have power all the way through the white would have it and grey would not or the switch would have it and not the wire. So the latest is I changed the wire connection on the switch came down stairs and cut and reconnected where white wire nutted into grey. I had power all the way through by the time I checked the light the breaker tripped. Or it tripped when I flipped the switch.
Thanks for any help you can spare!
