I have a large livingroom ceiling that is textured. It doesn't look like the typical "popcorn" ceiling to me. It is very hard and no pieces come off with rubbing. It isn't a uniform texture throughout - some areas are smoother than others. How was this done - with compound by hand?
I would like to smooth out the ceiling. It doesn't seem like wetting it down and scraping would work like removing a popcorn ceiling. Would painting smooth it out or am I looking at lots of sanding to smooth it down?
I don't hate the textured look BUT in the second picture you can see what appears to be paint roller marks? I am not sure if the ceiling was painted after this textured effect was done or if the roller made the textured look??? I can deal with a somewhat textured look but I would like to get rid of the roller marks. Is there a way to do that by getting a new coat of paint on it?
You may also notice the ghosting in the second pic. I have read about thermal bridging but am not sure if this is what I am dealing with or the fact that I have a 1940s house with a brick fireplace in this room that was used and the soot has collected on the beams because they are cooler in temp than the insulated walls. I was considering coating with BIN to hide the ghosting no matter what I decide to do.
There is one crack in the ceiling. There doesn't seem to be any water damage around it or anything else that seems like it would've cause the crack. My best guess is that someone was in the attic and didn't put his/her foot on the ceiling beam and put their foot down on the drywall instead and oops cracked it. Is there a way to fix this without removing that entire piece of drywall or sheetrock (whatever they make ceilings with?).
Can I get options for each issue? Thanks.
