The water pipes in my crawl space are wrapped with self-regulating heat tape (& insulation.) i removed a couple runs and froze them in a bucket of water to test and they do work. I am trying to verify that the installed runs are working. I do not currently own a megohmmeter /megger or a hand-held cable fault locator. I’ve tried using a current tester (“beeper”). I know this is not the correct tool but i want to get an opinion of what I am observing. The current tester is indicating current on the full length of some of the runs. A couple of runs it is showing current only up to a certain point. But the strangest is a run that shows current, then seems to have a dead spot, then indicates current further down the line. Is there any “most likely” explanations? Without getting the correct tool, it seems i am flying half-blind. Thank you.
Dave
Dave
