Good day,
I have a condenser fan that turns very slow or not at all. If I give the fan a spin it will turn fast for about 1/8 of a turn then stop. I tested the cap and it tested fine. Regardless I had a different one and tried it with the same result. I measured the resistance in the fan motor. It is three wire. The resistance in the lower two winding match the resistance in the common?? or other one. I do have continuity between two of the wires when ohming them out. My question is is this normal? Can I somehow plug this fan into a 220 outlet with the cap to test it? If so how? I have purple wire that was connected to the CAP, brown connected to fan and black connected to the circuit board
Thanks
Thanks
