I dont know if this is the proper place to post this.. as my question is 2 fold.. partly about termites but also about foundations.
a house im planing on moving into has a lot of termite dmg, infact i've seen termites on at almost every side of the house.
i contacted 2 professional exterminators. the lowest estimate was 1600 but was told it could easily go to 2400 or 2500 after work was started..
neither could give me a guarantee longer then 30days
it's my understanding it can take that long ot get rid of them in the first place.
i researched it and it seems termidor is about the best you can get, well actually you can't get it as it's not sold to the public.. but was able to aquire some on the internet.
and the stuff is'nt cheap, but a lot cheaper then a professional who can't give me any guarantee at all.
form my reading it seems the easiest home owner method of applying termidor is to use a 5 gal bucket to mix.. you dig a 6 inch wide 6 inch deep trench about 3 - 4 inch's from the foundation all the way around the foundation both in and out side the house.
and there is my problem.. the house is very old started as a log cabin and was added on to at least 3 times (previous owners) none of it looks like i was professionally done so the house has a lot of problems other then termites but this is obviously the largest and most house threatening one.
there i a dirt floor under neith, we intend to lay down some 6ml plastic barrior to keep moisture out, another problem is the road has been built up repeatedly where they repave it.. this has lead to a downward slope to the house for which im unsure how to correct, but that is another thread.
anyway the foundation is mostly made up of cinder blocks, the problem here is the blocks seemlying only go down about 1/2 of a block into the ground.. where my understanding it should extend down a couple of feet.
im afraid if i try to dig a trench that close to the foundation that it will undermind the soil they are sitting on.. and that would be very bad.
so i need advice and help from anyone who has applied termidor.. but especially in this sort of conditions.
Thanks in advance.
Thanks in advance.
